Latest post 11-28-2009 8:14 AM by Leslie. 9 replies.
Page 1 of 1 (10 items)
  • 11-24-2009 9:28 AM
    • samuk
    • Not Ranked
    • Joined on 01-31-2009
    • Posts 15
    CD6500
    Hello all
    Few months ago I had a problem with my CD player runs and stop.
    Some one in the forum asked to clean the master lences of the player which i did and
    player work fine after wards.
    But again now its not working . When i press the play button it goes back to the stand by mode.
    Can you help me. I feel sorry to move to another product and same time not in a position to buy another B&O
    player,
    Thanks,
    Kind Regds,
    Samuk
  • 11-24-2009 9:48 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: CD6500
    Samuk,
    Probably the common laser circuit fault.
    A fault that leads many repairers to believe that the laser itself has died and the player left irrepairable
    where the truth in most cases is that the laser simply doesn't get enough electric current to function correctly.
    Not enough current = not enough light.
    Not enough light = not enough reflection from the CD disc.
    Not enough reflection = presumably no disc present.
    No disc present = standby when play is activated.
    In the vast majority of cases, depending on the amount of degrading, it can be diagnosed by watching the laser diode
    after activating play with a CD loaded. Look in from f.e. the side of the deck.
    If the laser diode tries to focus on the disc (moves a few mm's towards - and away from the CD disc) but nothing
    else happens, the laser is probably lacking power.
    A fairly easy fix for a tech guy with the right knowledge.
    And usually not particularly expensive in that the repair often is just a matter of
    replacing a handful of capacitors. At least one of the capacitors needs to be of the correct value, specs and even
    brand and type. Ready-made capacitor kits are available for some CD deck versions but it does take basic electronic
    skills and tools to do the job.
    Whatever you do - DON'T adjust anything.
    Panic, desperation, trial and error etc. will not cure the thing, it will only increase the repair bill because of the
    hours needed to get everything right again.
    It's very tempting to raise the laser current. It may bring some kind of life back to the player but not for
    very long (think minutes rather than years) and there's a huge risk that it will do irreversible damage to
    the laser diode.
  • 11-24-2009 6:36 PM In reply to
    Re: CD6500
    Hi Martin,
    Since you're one of the experts here I really need your help or advice.
    My Beogram CD50 player is acting strange! The CD drawer now continuously opens and closes. Even with or without putting in a CD disk (if I get the chance to put a CD in it).
    Do you know what could be wrong?
    Thanks in advance, Leslie
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 11-25-2009 2:23 AM In reply to
    • Dillen
    • Posts 5,008
    Re: CD6500
    Leslie,
    There are a couple of switches that are actuated by the sequence wheel under the CD drive.
    They often oxidate, especially if not used for a long time, and they will need cleaning.
    I like to take it apart and clean the discrete parts ultrasonically but the "kitchen table"-way is to soak a piece of
    paper in contact cleaner, insert it between the closed contacts and slide it back and forth
    a couple of times. Open contacts will need a gentle finger-help to close a little to sandwich the paper or a rotation
    of the sequence wheel to close.
    It can also happen that one of the leads that goes to the switches have come off. Not always obviousl since they
    are sometimes also glued for stability but a gently and tiny pull (or measurement) will tell.
  • 11-26-2009 7:02 PM In reply to
    Re: CD6500
    Thanks Martin, helpfull as always!
    Found 2 switches at the rear that can be reached without dismantling the CD unit. But they seem to be okay using a multimeter.
    Also found one on the side near the "open" button. Unfortenately problem remains and I don't have the skills to open the whole unit.
    Any other suggestions Martin or will it be a costfull repair bringing it to the dealer?
    Thanks, Leslie
  • 11-27-2009 2:03 AM In reply to
    • Dillen
    • Posts 5,008
    Re: CD6500
    Repair costs vary a lot on these slightly older things. Some repairshops reject them altogether.
    I've done many and yours are welcome here as well but I'm in Denmark
    and depending on your location shipping back and forth could be expensive.
    If the tray is very slow acting, the circuit may time out and the system gets confused. Taking the whole mech. assy apart, cleaning
    and lubricating is the way forward in this case. Mark everything, especially the way the cogs grip into eachother, it will have to come
    back together in exactly the same positions. Not the easiest task and definitely not recommended for the untrained.
  • 11-27-2009 7:06 PM In reply to
    Re: CD6500
    Thanks Martin,
    Will keep your offer in mind. Have to check how much shipping costs are!
    Keep you posted via personal mail if you don't mind.
    Thanks again for your help, much appreciated!!!
    By the way, have been in Denmark few months ago for my work and also visited Struer while I had the oppurtunity.
    Sadly it was on a Sunday, so everything was closed but at least I've seen the factoryStick out tongue
    Leslie
  • 11-28-2009 3:39 AM In reply to
    • Dillen
    • Posts 5,008
    Re: CD6500
    You're welcome.
    I have lived all my life in Denmark, collected B&O audio products since the mid-70's and I never visited Struer... Laughing
    Maybe some day.
  • 11-28-2009 7:28 AM In reply to
    Re: CD6500
    Dillen:
    Surprise
    That's like an American never making it to Wally World! Wink
    • B&o bottle opener
  • 11-28-2009 8:14 AM In reply to
    Re: CD6500
    Or like this Dutch guy who never wear wooden shoesBig Smile
