Latest post 11-23-2009 9:02 AM by cooldude. 1 replies.
Page 1 of 1 (2 items)
  • 11-22-2009 4:45 PM
    AV 7000
    Bonjour,
    Can a Beo4 be used to control all fucntions on a BeoSystem AV7000?
    Regards.
    Filed under: ,
  • 11-23-2009 9:02 AM In reply to
    Re: AV 7000
    The beo4 will work.  I know for sure the early ones do.
    I use the BL1000 as it's way easier and faster in daily use.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
