Latest post 11-24-2009 1:39 PM by richtoy. 4 replies.
Page 1 of 1 (5 items)
  • 11-22-2009 12:36 PM
    • puck5862
    • Not Ranked
    • Joined on 05-29-2007
    • Sleepy Hollow, IL
    • Posts 13
    MCL 2p gone bad
    Hi All,
    I need some troubleshooting info for a defunkt MCL 2p.  No lights, I checked the fuses - they're good.  I hooked it up to my Bm 4500 and as soon as I hit an input (FM radio) the BM would go straight back to stand by mode.  Any ideas?
    Thanks in advance for your help.
  • 11-22-2009 1:34 PM In reply to
    Re: MCL 2p gone bad
    Has it worked before in this scenario? How is it connected?
  • 11-23-2009 12:13 PM In reply to
    • puck5862
    • Not Ranked
    • Sleepy Hollow, IL
    • Posts 13
    Re: MCL 2p gone bad
    Here's the bad news.  I purchased it off ebay with intent of connecting to my AV7000.  When I first got it, I just plugged it in to see if it lit up.  It did.  Now it doesn't.  I checked the connection to the BM 4500 with my othe MCL 2p and the connection worked for that one.  So I don't think I had it connected wrong.  I took it apart and did notice some leakage out of the larger rectangular black plastic box on the left pc board.   I'm not sure what this componet is.  It certatanly does not look like a capacitor.
  • 11-23-2009 7:18 PM In reply to
    Re: MCL 2p gone bad
    can you post a photo of the area that is affected and the leaking component ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 11-24-2009 1:39 PM In reply to
    • richtoy
    • Top 500 Contributor
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    Re: MCL 2p gone bad
    If the black rectangle to which you refer is 2.5" x 1.75" and the stuff leaking out is white then it is normal.  The device is a power amplifier integrated circuit and the white stuff is heatsink compound.
    Unfortunately there is no service manual for the MCL2P on the site so further help is a little tricky...
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
