Latest post 11-22-2009 1:41 PM by ed7. 5 replies.
Page 1 of 1 (6 items)
  • 11-21-2009 2:07 PM
    beolab 8000 how to connect to non BO tv???
    Ive purchsed a set of two 8000 speakers and i am struggling to connect to my panasonic tv, ive ran a power lead to each speaker and a audio lead to each L&R from the audio out rear of the tv, ive set the speaker at rear to line and the volume is to high and doesnt turn down when i use the tv remote!!! wot am i doing wrong.. thanks
  • 11-21-2009 4:10 PM In reply to
    Re: beolab 8000 how to connect to non BO tv???
    Maybe this would be helpful...:
    http://forum.beoworld.org/forums/p/12190/90595.aspx#90595
    And this:
    http://soundsheavenly.co.uk/bando-beolinkrca.htm
    -Dimitris
  • 11-22-2009 10:32 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Chances are that your TV has a "fixed" volume audio output.  This means that the audio output level does not change.  Look at the owner's guide or look closely to the back of the TV and the word "fixed" may be printed near the output jacks.
    If you are lucky, your TV has 2 sets of audio output jacks.  One is fixed, the other is variable.  In this case, just swap the cables on the TV to the variable output jacks.
    If you are not lucky, and your TV only provides a fixed output, then you need something to provide the BL8000s with a variable output.  The easiest approach is to use a stand-alone pre-amp.  Make sure to get one with a remote control.  Alternatively, you could invest in a B&O audio master (BS3000, BS4, BS9000) that has an AUX input (note that the BS5/BM5 does NOT have an AUX input).  You will probably need an RCA to DIN cable for this connection.  Run the TV into the AUX port of the BS and connect the BLs to the BS.
    Stan
  • 11-22-2009 11:53 AM In reply to
    • ed7
    • Top 200 Contributor
    • Joined on 12-06-2007
    • uk
    • Posts 297
    I have asked this question few times to different dealers over the years  they always said you can not connect b&o speakers (active) to a non-b&o tv set??? ,wonder why???Surprise
  • 11-22-2009 12:55 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    ed7:
    Maybe because they want to sell you a BV? Wink
    Quim
  • 11-22-2009 1:41 PM In reply to
    • ed7
    • uk
    • Posts 297
    Quim43:
    ed7:
    I asked that even before bv7!!!
    Cool
