Latest post 11-20-2009 10:31 PM by jk1002. 6 replies.
Page 1 of 1 (7 items)
  • 11-19-2009 10:06 AM
    Apple TV vs Archos TV+
    anyone used either?
    I'm thinking of Archos at the moment through a BV8 linked to BL6000's.
    not too bothered about streaming. However does anyone know if you can use the Archos remote whilst the main unit is hidden away?
  • 11-19-2009 10:27 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Apple TV vs Archos TV+
    Sorry, no idea - but I suggest to take  a look at the Popcorn Hour. This should be in the PUC list.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-19-2009 11:40 AM In reply to
    I kind of agree, PS3, ATV or popcorn .... somthing like that ... while would you introduce Archos if the BV can control the earlier ?
  • 11-20-2009 4:19 PM In reply to
    Do you mean that Apple TV can be controlled through the BV using Beo4 /5 ?
    If thats the case, then its a no brainer
  • 11-20-2009 5:07 PM In reply to
    • Affineur
    • Top 500 Contributor
    • Joined on 04-27-2008
    • United States
    • Posts 90
    Yes, ATV can be controlled by Beo4/5. I have a similar set-up to what you are considering: BV8, ATV, Tivo, BL3s. Everything is controlled through a Beo4 via the BV8 ir blasters and all boxes are hidden from view. Very clean.
    Seek simplicity and distrust it. Alfred North Whitehead
  • 11-20-2009 10:31 PM In reply to
    Hello B&O in Denmark. Obviously you are not advertising the merits of the STB concept enough.
