Latest post 11-21-2009 9:16 AM by IngvarW. 1 replies.
Page 1 of 1 (2 items)
  • 11-18-2009 3:25 AM
    BS5 Playlist Problem
    Hi all,
    after no-one in the german forum could help me, i try to explain my problem in the international forum.... (sorry about my bad english)Embarrassed
    In the past, i can manage my playlists on the BM1 with the beoplayer, by creating an new playlist and deciding whether this playlist should be on the PC only, an the BM1 only or on both of them... so far so good ;-)
    After changing my configuration to a new System BM5 with BS5 i want to do the same. In the Manual of the Beoplayer (pg 19 / SW 5.03.00) it should be possible to create a Playlist and choose the avalibilty by a right-click on the "NEW-Playlist" Button....
    I get no possibility to choose this.... i can only create a local playlist. I tried everything, new SW Installation other PC, other SW-Release... all i know abaout, but nothing helps....Super Angry
    Anybody there who have an idea to solve the problem ???Confused
    Thx´s
    Niederrheiner
  • 11-21-2009 9:16 AM In reply to
    Re: BS5 Playlist Problem
    When I test in my Beoplayer only the colored playlists are copied to my BM5 from the PC. The numbered playlists on BM5 doesn´t seems to be syncronized with the playlists in BP that you can name by yourself and vice versa.
    Bgrds ingvar
    Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
