Latest post 04-20-2010 2:44 PM by mr_anders_son. 5 replies.
Page 1 of 1 (6 items)
  • 11-17-2009 2:46 PM
    • pnr
    • Not Ranked
    • Joined on 10-25-2009
    • Posts 21
    Puc codes for Popcorn c-200
    Does anybody knows if there is PUC codes for Popcorn c-200. I know that it uses RF insted off IR for remote, but it should be possible to buy a IR kit for it.
    Is there anybody that have experience with Popcorn c-200 and B&O
    Thanks in advance
  • 11-17-2009 3:33 PM In reply to
    Re: Puc codes for Popcorn c-200
  • 11-18-2009 12:54 AM In reply to
    • pnr
    • Not Ranked
    • Posts 21
    Thanks for your reply!
    i know that there is codes for the Popcorn hour a-110, are you sure that there also is codes for C-200 or is it the same codes?
  • 04-20-2010 9:35 AM In reply to
    Maybe Keith can shed some light on this? I would almost say, since the codes for the A-110 are there, the C-200 will work ( for most of the keys?).
    I am basing this on the following information:
    http://www.networkedmediatank.com/wiki/index.php/Remote_Control_A-200/C-200#Pronto_Remote_Control
    http://www.networkedmediatank.com/wiki/index.php/Pronto_Remote_Code_list
    But as said, I am no expert on the matter but Keith is.
    Thanks, Peter.
  • 04-20-2010 1:46 PM In reply to
    I was also looking for PUC code to C200, but since I was in doubt, I decided to go for the Tvix M6600. With the new Firmware (1.9.8) it works great.
    The control from linkroom TV's also works fine, but you would then need to connect the Tvix with both HDMI and Composite.
    There is something about B&O.....
  • 04-20-2010 2:44 PM In reply to
    beolion:
    But Tvix 6600 dont send on both HDMI and Composite at the same time!...or?
    My Tvix 6500 does not
