Latest post 11-18-2009 10:46 AM by Flappo The Grate. 3 replies.
Page 1 of 1 (4 items)
  • 11-17-2009 2:38 PM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Please help BV7 with SKY HD driving me mad
    Hello All
    I have a  BV7 mk3 connected to SKY HD box
    Recently my sound drops for for around a second at a time and its driving me mad.
    this happens on recordings and watching tv
    the signal quality and strength are fine
    sometimes its lots and others now and then and is complely random.
    sometimes it does it every few seconds and there is no disruption to the image on the screen.
    please help me has anyone had this?
    My ATV works fine and does not have an issue?
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 11-17-2009 3:49 PM In reply to
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    Re: Please help BV7 with SKY HD driving me mad
    To save you from being sent to the sanitorium ask your dealer to swap you their sky box for yours for a couple of days.
    They will be know for sure that their box is fine, if your box shows the same symptons in their showroom and the their sky HD box is fine in your home you'll know for sure it is the box or otherwise?
    Hope this helps.
  • 11-17-2009 3:52 PM In reply to
    • ed7
    • Top 200 Contributor
    • Joined on 12-06-2007
    • uk
    • Posts 297
    Have you checked the cables connections on both sky box and tv??maybe one  connection is not fully secured!
  • 11-18-2009 10:46 AM In reply to
    probably the sky box
    i've got 3 dotted aboot the castle and they're all utter &*%$
    popgear is grate™
