Latest post 07-03-2007 4:39 PM by Peter. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • 07-02-2007 3:22 PM In reply to
    Re: Fitting STB-C to MX4002
    Codes now on - look in the manual section for the AV9000.
  • 07-03-2007 4:29 PM In reply to
    Thanks for the info Peter,
    I have now programed the STB-C to code2 but I am still not getting any response................!!Sad
    I will have to check all the connections during the weekend. I did notice that when I disconnected and reconnected the IR cable for the STB-C connection in the back of the MX the TV switched on the analogue tuner!!Hmm
    Simon
  • 07-03-2007 4:39 PM In reply to
    It did take the Newcastle technician two and a half hours to do mine and we had a few false starts! Mine wouldn't work with the most up to date software so we used 2.0
