Latest post 11-14-2009 5:36 PM by Andy . 7 replies.
Page 1 of 1 (8 items)
  • 11-13-2009 1:07 PM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    Beolink 7000 and BC 7000
    Hi i have purchased a beolink 7000 for the use with my BC 9500 but it only seems to work one way?? I have had a look at the previous threads and deleted the sources and added again but still no joy. I cant even set the clock properly.
    My question really is there a setting on the BC that uses one way or 2 way that I can change?? ( I have been using the BL1000) Or is it a problem with the 7000 that I read about in the threads??
    Any help appreciated!!
  • 11-13-2009 1:09 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Re: Beolink 7000 and BC9500
    sorry it should read BC9500!!
  • 11-13-2009 2:04 PM In reply to
    I take it you just get no contact. Possibly a fault in the transceivers - these are complex remotes and are getting less reliable with age. Ridax seems a bit of a whizz mending these!
  • 11-13-2009 3:15 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Thanks Peter yes no contact at all even if it is in the docking station. Shame as i love the look of it with my BC9500 but now no better than the BL1000 but with lights!
    Andy
  • 11-13-2009 3:19 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Just a quick question would the beo 5 work with a BC9500??
  • 11-13-2009 4:00 PM In reply to
    Yes - only one way obviously.
  • 11-14-2009 8:15 AM In reply to
    My BL7000 hade the same fault not too long ago, had it to a electronic repair shop and they replaced 3-4 capacitors. It was about 60 euros if I remember correctly... The materials cost really nothing, it just a pain to open up these things.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 11-14-2009 5:36 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    its just knowing someone who can fix these things in the UK?? Any Ideas??
