OK Simon, based on your statement then I am guessing that we are likely to be looking for a component breakdown or change of component tolerence as the set heats up.
You stated that it is a "Flicker" which manifests itself as a line anywhere on the screen.
Are you talking about a horizontal line and if so is it a scan line thinkness or wider ?
