Hello everybody,
I will sooner or later add a 4x2 HDMI splitter to my BV8 40 setup, in order to get 5.1 sound with movies on my videoprojector (BV8 in P.mute, videoprojector for the image).
I thought of buying a cheap 4x2 matrix like that http://cgi.ebay.co.uk/4x2-SWITCH-SPLITTER-v1-3b-1080p-HD-HDMI-TRUE-MATRIX_W0QQitemZ110447121717QQcmdZViewItemQQptZUK_ConsumerElectronics_VideoSwitches_SM?hash=item19b7295535
(As long as I switch on only one source at a time, I shouldn't need to remote control the switch and the picture of the powered source will automatically be sent on the two devices)
But I've learned that the new BV8 software allows to control a HDMI switch : as I understand it, that would allow a little bit more flexibility like quick source change, so it would be like the BV8 has 5 HDMI inputs (and one output for the projector)
So here is my question : which HDMI switches can be controlled by the (updated) BV8 PUC? And is there any 4x2 matrix switch among them??
