Latest post 11-11-2009 5:45 PM by Stan. 4 replies.
Page 1 of 1 (5 items)
  • 11-11-2009 2:19 PM
    • mib
    • Not Ranked
    • Joined on 11-11-2009
    • Posts 1
    BS5 - Sony tv audio
    Hi All,
    About to become the proud owner of a BS5/LAB3 system - and as I am all new to B&O I have one question which I have tried to seek answers to. At home we have a Sony Bravia TV. Is it possible to connect the audio output from this into the BS5 somehow- and/or is there something to consider? (BeoVision is not happening just now)
    As I said about to become an owner so I havent gotten the actual unit yet (should arrive friday).
    /MiB
  • 11-11-2009 3:14 PM In reply to
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    Re: BS5 - Sony tv audio
    It seems that there are no inputs on the BeoMaster 5 unit.
    /MikaelB
  • 11-11-2009 4:45 PM In reply to
    I have a Beosound 5.  There is no Aux input.  Check with your dealer as there may be other options.
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 11-11-2009 5:37 PM In reply to
    • Stan
    • Top 150 Contributor
    • Posts 593
    • Gold Member
    There is a little known feature of a BeoLink Active that allows it to accept audio input via the PC port.  I have a Toshiba LCD TV that I've connected the audio output to the PC input on the active.  You press "PC" on the Beo4 to have the Active send this audio to the speakers.  You do need to connect this via MasterLink to the BM5.  The TV audio is not distributed via ML, and the active can play the TV audio while the system is playing something else.  I went one step futher and bought and programmed a Beo5 so I can turn on the TV, Cable Box and speakers with a single button.  It works great.
    Finding the correct cable was difficult.  Most dealers do not know about this option.  I believe it was originally developed for the BeoLink PC product (the idea was the take the computer's audio output and pipe it into the active) which predates the BeoLink PC2/BeoPort.  If you search the archives there is a thread where the part number of the this cable can be found.
    I'm actually planning to do this again for another TV in the house so I will take a stab at finding this in the archives.
    Stan
  • 11-11-2009 5:45 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Here's thread where there is much information about this capability:
    http://forum.beoworld.org/forums/p/15997/118815.aspx
    To cut to the chase, the part number that I ordered from B&O America was 0898126
    Although, Keith Saunders mentions that the part number was 6270759
    Stan
