1st March February 2012
Latest post 11-22-2009 4:07 AM by moxxey. 62 replies.
11-11-2009 5:48 AM
dueno
- Joined on 04-29-2007
- bordeaux
- Posts 147
Re: BeoVision 7, 55'' pictures now in media center
I NEED IT!!!!!!!
with beolab 10!!!!!!!
never explain never complain
Medic394
- Joined on 04-20-2007
- Posts 68
Hi all,
Just been reading a report of the new Beovision 7. 55 on www.engadget .com it has a good wright up on it.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
First I did´n't think it was that big, but then I realized the speakers next to it are BL 8000!
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
I find the set beautiful, I'm waiting for the specs but can't help wondering why they released pictures of it on the floor with the table stand, it looks like you have to bend on your knees whenever you want to insert a DVD, and they seem to think that your ears are located at ground level when playing with BeoLab 7-6 only..
How will it be priced compared to a BV9, I'm curious to know too..
Reunion Island is greeting you!
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
http://www.prnewswire.com/news-releases/bang--olufsen-announces-beovision-7-55-inch-with-improved-lcd-picture-technology-69738567.html
http://www.engadget.com/2009/11/11/bang-and-olufsens-beovision-10-lcd-grows-to-55-inches-makes-room/
It's launched for the US, in stores middle to end of november.
Daniel
- Svinarp, Sweden
- Posts 1,284
Chrisreunion:
Don't worry, you will hear it even if you're hanging in the lamp.
markiedee
- Joined on 07-19-2009
- Posts 105
i think it looks beautiful a nice addition to the 40 inch version you should really get a cinematic experience with that i want it to!!
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
Somehow, I never really liked the BV 7. But as a 55'' it works rather well. Too big for my apartment, though...
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Hungedu
- Joined on 08-08-2009
- Ambergris Caye, Belize
- Posts 128
What's up with the 120Hz panel on the new BV7-55? The smaller, less expensive BV10 has a 240Hz panel. At least it's LED backlit, but the BV10 is still a better buy for the money.
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
MikaelB
- Herning, Denmark
- Posts 191
Here is the official B&O press-release.
/MikaelB
R Patton
- Kansas
- Posts 162
Ok, it's a bigger BV-7, but whats with the BL7-6? The thing extends beyond the sides of the TV frame and looks silly IMHO. Why not use a BL7-2?
I can see where a BL7-6 might look better under a BV 4 65" but under the BV 7 it looks ill fitting and unbalanced.
elephant
- Melbourne, Australia
- Posts 2,215
Chrisreunion: you have to bend on your knees whenever you want to insert a DVD
... a suitable sign of respect and devotion
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
BeoNut1
- Joined on 08-19-2007
- Mobile, AL (USA)
- Posts 226
Guys,
Quick question: is the "low floor stand" really meant to only be used as a floor stand?
The reason I ask is that I'm interested in this TV (I've been waiting for B&O to do a larger LCD), but within the confines of the shelves that I would put this TV in, a table top, motorized stand would seemingly be the best solution. However, I get the impression from B&O's press releases that the low floor stand isn't intended to be put on a shelf. Thoughts?
TIA,
Mark
Mark D
Daniel
- Svinarp, Sweden
- Posts 1,284
elephant:
Daniel
- Svinarp, Sweden
- Posts 1,284
BeoNut1:
Why not, as long it can take the load from the set?
BeoNut1
- Mobile, AL (USA)
- Posts 226
Whoops, I thought of another question right after I hit the "return" key with the last post.
Ever since the BV-7 55" was first rumored, I've envisioned getting this TV and starting to set-up a surround system with this TV as the center of the AV system. Actually, I envisioned initially using my BL-3s as a temporary set of front speakers with the idea that I'd eventually move the BL-3s to the rear and get some larger front speakers. The area that I'd put the TV, as well as my financial situation, dictated using smaller front speakers initially.
However, now that I see how really large the BeoLab 7-6 looks, I'm wondering what the use of the BL-3s as front speakers would be. What are the thoughts of the group regarding a pair of BL-3s versus the BL 7-6 as front speakers for this TV? Ideally, I'd like to stick with ALT speakers, but I suspect that the BL 7-6 is going to be close to the BL3s in terms of sound (maybe even have better bass), and I suspect that a BL 7-4 might be too small a center speaker for this TV when used alone.
TIA,
Mark
Mark D
beocool
- the Netherlands
- Posts 5,514
elephant:
Daniel
- Svinarp, Sweden
- Posts 1,284
I spent the evening yesterday trying to figure out how it would look with the BV 7-55. It will fit with the high stand, but I like it the look of the low stand more and more.
The problem is that soundwise I want the BL 7.4 (monospeaker with alt) to use with my BL8000. But the low stand will take out the size of the TV a little bit and make the set less dominant in the room. Then I probably would move the BL8000 and use them somewhere else in the house. On the other hand it would feel strange not to have a 5.1 system with that TV.
Daniel
- Svinarp, Sweden
- Posts 1,284
BeoNut1:
Tricky, I know. We must spend some time in the store and also maybe get a home demo on this.
BeoNut1:
No problems. BL10 (almost the same speaker as 7.4 can be used with BV 4-65 and 4-103.
BeoNut1:
spezializten
- Joined on 05-09-2008
- Posts 35
I totally agree with you Daniel. When speaking about the surround sound the BL 7-6 isn't the perfect speaker as a center but I don't think the BL 7-4 matches the size of the TV. I think I will start with the wall bracket for the TV and have the BL 7-6 on a table/shelf below.
I wonder how the BL10 will look together with BV7-55? I think I have to mount the TV to high when using BL10?
Daniel
- Svinarp, Sweden
- Posts 1,284
spezializten:
Think it will work as BL10 is designed to be wall hanged with big flat TVs.
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Will it have the Adaptive Sound Technology enabled when first released?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
