Hello,
I'm new to the forums and B&O products. I recently started this path by getting a good deal on a Beosound 1 and was amazed by the quality and features of such a small little unit. I am interested in getting started on a basic setup and don't have a lot of money. So, I was looking at a used Beocenter 9500 and perhaps in a bit getting some speakers to go with it.
In the meantime, was thinking it would be great just to use the Beosound 1 with it, as it has a 5-pin DIN AUX input that can be connected to a minijack through an adapter cable. Here are my questions:
1) If I connect to this through the headphone jack on the Beocenter 9500 will this turn the main R and L speakers off if I also have a speaker connection via the powerlink? In other words, would connecting a pair of headphones (since this is equivalent to the Beocenter 1) mute the main speaker output?
2) Is there a cable to connect this 5-pin DIN AUX on the Beosound 1 to the regular R and L channels on the back of the Beocenter 9500 if I don't have any extra speakers for now?
3) Will the optional Beo4 remote control both units?
Thanks!!
