Latest post 11-11-2009 2:28 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 11-09-2009 6:13 PM
    • Alex
    • Not Ranked
    • Joined on 12-01-2007
    • Canada
    • Posts 4
    TX-2 (Type 5913) Tone Arm
    Here`s the situation:
    Everything about the table seems to be working great with the exception of the tone arm.
    For some reason when I begin to play the record, the tone arm and cartridge/stylus doesn`t lower enough to touch down and play the beginning of the record. Instead, it glides and finally lands near the end of the record. It`s similar to an airplane landing. When it finally touches down, it`s a little bumpy at first, but then it`s all good for the rest of the way.
    My MMC4 cartridge has been taking a beating due to this...but I have no problem replacing it with a SMMC4.
    Any info on how to resolve this issue?
  • 11-10-2009 5:21 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: TX-2 (Type 5913) Tone Arm
    The carriage slides on a steel track bar, clipped to the subchassis plate.
    Sounds like yours have lifted off at the rightmost end.
    Was it transported/shipped ?
    Opening of the Beogram is needed to reach the spot so if you are not
    very good with mechanics, I suggest you bring it in for service.
    If my diagnose is correct it won't be an expensive repair.
  • 11-10-2009 6:41 PM In reply to
    • Alex
    • Not Ranked
    • Canada
    • Posts 4
    Looks like I`ll be bringing it in for service.
    I actually won it on eBay. It was packed well, but it didn`t have its original packaging. Any suggestions on how to transport it from now on without causing further damage?? (Aside from tightening the transport screws)
    Thanks for the info!
  • 11-11-2009 2:28 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, squeeze a thin block of foam in between the top of the carriage and the black plastic rear cover to hold
    the carriage down.
    Also place foam pieces around - or under and above the arms to provide a light sandwich-squeeze when the lid is closed.
    Of course making sure not to bend the arms in the squeeze.
