Hi Dave,
there should be no such thing as a 900F so I presume you mean either M or K - anyway, the chassis is the same.
The dial lamps are originally type 8024, which is 6.3V, but the stereo indicator lamp is supposed to be 19V / 100 mA. A 6 volt bulb will definitely burn out there! The 47 ohm / 1W series resistor belongs there. Don't use a bulb with a higher current rating since then the switching transistor of the stereo decoder (if you have one) will be in danger.
If you have trouble finding a 19V bulb, 24V/0.1A bulbs should be easily available and will work fine, just a little dimmer.
A service manual is on site for silver and gold members, but it may not be that useful - there were a lot of different variations of the 900 and the only schematic you can trust was put in an envelope inside your Beomaster at the factory. Some people have an annoying habit of removing them...
