Latest post 11-08-2009 3:20 PM by Kiwi. 0 replies.
Page 1 of 1 (1 items)
  • 11-08-2009 3:20 PM
    • Kiwi
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 45
    Two STB's: PS3 + Another STB-C doesn't work
    I have a problem with the following setup:
    BV4-50 with Beosystem2 (SW16.2, STB-C table 4.11). PS3 Slim connected to AV (or DECODER) via SCART on the Beosystem2.
    IR lead via a Nyko BluWave (connected via USB on the PS3) to the IR-out jack on the Beosystem2.
    PS3 as the only STB -->  OK
    If I select the PS3 as the only one STB (V-AUX) either on AV or DECODER everything works great. I can use the Beo4 to navigate on the PS3 without any problem.
    Select a 2nd STB  -->  Not OK
    From the moment that I select a second STB (any one, even PS3), the Beo4 can't control the PS3 anymore. Ex. PS3 (V-AUX) on AV and Humax (SAT) on DECODER --> The Beo4 can't control the PS3 anymore.
    I tried both: with and without the B&O Y-cable. Every time I select a 2nd STB, the Beo4 can't control the PS3 anymore.
    Anyone know how to fix this ?
    (Or is it a known bug ?)
