Has anyone else noticed that a couple of versions ago the Configuration setting here you could select the portable device copying quality has been removed.
I have a beosound 2 and it is now basically useless with this setting gone. I copy CD’s in Lossless and the BS2 SD cards can’t hold to many tracks in that format. Must be time to upgrade to an iTouch....
Does anyone else miss this feature? Is there any other way to transfer to the BS2 is different or lower resolution?
FYI Beoport version 5.03 installed and runs without issues on windows 7 32 bit
BV10, AvantDVD, BS3000, BL8000, BL6000, BL4000, BL3500, BeoPorts, BC9300, BC7002, CX100s, C75s, Beo4s, BC6000s, LC2s, A9, A8s,
