Latest post 11-08-2009 8:23 PM by bruno_destickere. 2 replies.
Page 1 of 1 (3 items)
  • 11-07-2009 8:17 PM
    Beogram CD5500 and Beomaster 5000. => [:S] 3 QUESTIONS [:S] <=
    Hello,
    I am looking for a Beogram CD5500 for my Beomaster 5000. => Unsure 3 QUESTIONS Unsure <=
    Will the CD5500 work on my Beomaster 5000 with my MCP??
    Can I use the Tape 2 input, because I've already a CD-player (CD50) on the AUX.
    Can I put 2 players on 1 input (with an adaptor) without loose the datasignal for operating with my MCP?? (a 7-pin DIN adaptor??)
    Thanks a lot for helpSmile!
    Bruno Destickere
  • 11-08-2009 2:49 AM In reply to
    Re: Beogram CD5500 and Beomaster 5000. => [:S] 3 QUESTIONS [:S] <=
    bruno_destickere:
    Will the CD5500 work on my Beomaster 5000 with my MCP??     Yes
    Can I use the Tape 2 input, because I've already a CD-player (CD50) on the AUX.  Not and use datalink - the CD player behaves like a record player and does not respond to Tape commands.
    Can I put 2 players on 1 input (with an adaptor) without loose the datasignal for operating with my MCP?? (a 7-pin DIN adaptor??) How will the machines know which one you are talking to? If there is a way so only one is connected at a time, yes.
    Bruno Destickere
  • 11-08-2009 8:23 PM In reply to
    Hi Peter!
    Thanks a lot for the quick reply (and this on Sundays...Smile)!
    I've already read a lot of your postings and again I am honoured (as Belgian) to have post back from  a 'specialized guy' like you !!
    It's indeed quite logic that the Beogram CD on tape2 does not respond to 'tape' commands... .Laughing
    So, I'll have to connect the CD5500 to the Aux with an adaptor (with a switch!) so I can still use my CD50 when I want... .
    (My opinion: it's better to wear out than to rust out!!)
    I've just buy one for a good price: http://cgi.benl.ebay.be/ws/eBayISAPI.dll?ViewItem&item=220504111653&ssPageName=STRK:MEWAX:IT
    Regards,
    Bruno Destickere
