Latest post 11-09-2009 12:00 PM by Louis. 5 replies.
Page 1 of 1 (6 items)
  • 11-07-2009 5:18 PM
    Connecting Beomaster 5 to BV7-40
    I am just about to buy the Beosound 5 together with the Beomaster 5.
    In order for me to figure out how to run the cables, I wanted to figure out how many cables goes between the BM5 and the BV7 ?
    I know the masterlink cable is one, but is there also other cables needed ?
    Thanks.
  • 11-08-2009 10:06 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Connecting Beomaster 5 to BV7-40
    My BM5 is connected to my BV7-40 MKIII via Masterlink (for controling and distributing sound to link rooms), spdif (for digital audio), stereo rca cable (analogue audio), HDMI cable (DVI - HDMI, for picture), and rca video cable (for distributing composite video to link rooms - "future use"). Everything is working fine.
    Hope this helps.
    Stefan
  • 11-08-2009 4:44 PM In reply to
    Thanks a lot Stefan.
    That seams like an awful lot of cables ? In my setup I will currently not use the link function to other rooms.
    Does that mean I need the following cables wetween the BM5 and BV7; DVI-I ->HDMI, Masterlink, spdif ?
    Do I need the stereo rca cable ?
    Thanks again.
    BR Jesper
  • 11-09-2009 7:58 AM In reply to
    • stefan
    • Posts 1,733
    I don`t know much about your setup, but Masterlink, DVI/VGA and analogue audio should work. spdif is meant for direct use with Beolab 5.
    Stefan
  • 11-09-2009 11:47 AM In reply to
    I dont have the BS5, only the BM5, and it is connected to BV7-40 mkIV with DVI->HDMI and s/pdiff.
    It works, but I have a humming noise from the speaker, which I have been told should be fixed with the BV7-40 Update in week 48.
    I am very much looking forward to this update.
    /Leo
    There is something about B&O.....
  • 11-09-2009 12:00 PM In reply to
    • Louis
    • Not Ranked
    • Joined on 07-26-2009
    • Posts 42
    • Gold Member
    I use the BM5 with Beosound 5 and the BV7 IV and the BM is only connected with the BV7 with the masterlink. All working fine!
    Louis
