Latest post 11-08-2009 3:26 AM by LarsJensen. 4 replies.
Page 1 of 1 (5 items)
  • 11-07-2009 4:59 PM
    • LarsJensen
    • Not Ranked
    • Joined on 04-25-2007
    • Copenhagen, Denmark
    • Posts 65
    Beovision 7 as link room TV?
    Can anyone tell me if it is possible to use a Beovision 7-32 or a Beocenter 1 as a link room TV? We would like a local DVD without loosing the acces to central HDD recordings etc and we would prefer an integrated solution rather than adding a DVD to the link room BV 6.
    The master TV would be BV7-40 MKIII.
    /Lars
  • 11-07-2009 5:34 PM In reply to
    Re: Beovision 7 as link room TV?
    The BV7 is fine - you would need to check that the BC1 has the link module fitted.
  • 11-07-2009 5:43 PM In reply to
    • LarsJensen
    • Not Ranked
    • Posts 65
    Thanks peter.
    All I need to do is just set the right option at it should work as a "slave" in the setup?
    /Lars
  • 11-08-2009 2:57 AM In reply to
    Exactly - it is in the reference book.
  • 11-08-2009 3:26 AM In reply to
    • LarsJensen
    • Not Ranked
    • Posts 65
    Thank you. Just the solution I was hoping for.
    /Lars
