Latest post 11-07-2009 1:43 PM by vikinger. 1 replies.
Page 1 of 1 (2 items)
  • 11-07-2009 1:17 PM
    Beotalk 1200
    I suddenly lost the dial tone and can't get it back.  I have tried turning on and off the answering machine.
    Does anyone know how to solve this problem?
    Flidyard
    Filed under:
  • 11-07-2009 1:43 PM In reply to
    Re: Beotalk 1200
    My Beotalk had a problem that was due to a loose connection at the splitter box. Solved with an elastic band! Do you have a dialing tone on the phone itself (with the Beotalk in place and without?) [..........at risk of stating the obvious but have you checked the line itself before concluding that there is a fault with the Beotalk?)
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
