Hi Opman,
Also on Winter hill and I had problems with my Beocentre 6-26, it just lost BBC1,2, 3 etc. all other channels seemed to be there. After trying everything I could think of I rang my dealer and he said that I would need to change a transponder frequency in the tuning list so it would then be able to find the missing stations.
To do this press menu, DTV, setup, options, then press RED then GO and this brings up the transponder list options. Go down to the 802MHz one then punch in 801133 then press go. this changed the 802 to the new frequency. Then you do a manual retune on the 801 that will now be in the frequency list and it will then find all the missing channels.
The shop also said that other frequencies may need to be modified in Dec when the final changes are made to the transmitters.
PS. Does anyone out there have any noticeable hiss on the sound (that only stops is the sound is muted) when using DTV on a Beocentre 6, or is mine faulty?
Hope this helps
Steve
