Latest post 11-05-2009 3:44 PM by John. 2 replies.
Page 1 of 1 (3 items)
  • 11-05-2009 6:43 AM
    • John
    • Not Ranked
    • Joined on 09-20-2009
    • BRISTOL UK
    • Posts 62
    • Silver Member
    beocenter9000 back glass panel
    I have a Beocenter 9000 with a damaged rear back panel. Is there any chance of finding a replacement? Unfortunately I am not in a position to collect it but would be quite happy to pay the additional cost of suitable packing and carriage.
    I am located near Bristol UK  and frustrated by the "cracked " 5cm of glass at the extreme right of the panel. It is glued together and patched with resin so it is serviceable but spoils the elegance of a fine looking instrument.
    Help please
    John
  • 11-05-2009 11:02 AM In reply to
    Re: beocenter9000 back glass panel
    The glass for the BC9300 is available from B&O. Costs around £80 and is a very passable replacement.
    Regards Graham
  • 11-05-2009 3:44 PM In reply to
    • John
    • Not Ranked
    • BRISTOL UK
    • Posts 62
    • Silver Member
    Many thanks Graham,
                                       It looks as the solution to my problem is not as hopeless as I had thought. I wondered whether parts for a similar model would fit, usually I have found there is just a small difference that makes a straight replacement unworkable.
    Regards
    John
