My Beosound Centry has started acting a little wierd lately. The source buttons are not working properly. When i try to start it using CD, Tape or Radio nothing happens. The aux button works though. When I use a remote i can choose a source without problems but the 3 source buttons will still not work. Once in a while though when i start it with the remote afterwards the source buttons will work.
Anyone heard about or had this problem before, and is there any chance there is a solution for it?
Thanks in advance
