1st March February 2012
Latest post 11-05-2009 11:01 AM by Peter. 8 replies.
11-03-2009 5:44 AM
KMA
- Joined on 08-13-2007
- Posts 101
AR coating on BeoVision 10
A long-time frequent BeoWorld Forum lurker (and a B&O fan for 20 years) here
I am going to purchase the new BeoVision 10, but am having a bit of difficulty in deciding if the optional anti-reflective coating is worth the extra cost (+750 euros).
Light (daylight) to my living-room will be coming from behind the television. What is your opinion, how much difference does the AR coating make if there is no direct sunshine (or bright light) to the screen?
Any thoughts and experiences are appreciated!
Thanks!
KMA
Current setup: BeoVision 10-46 (grey speaker cover, AR, motorized stand) with Apple TV 2 (FireCore), Sony BDP-S780, Mac Mini, BeoLab 11 (silver), Beo5, BeoSound 8 (red speaker covers). Accessories: A8 Earphones, wine bottle coasters.
B&O product history, in chronological order since 1990, after the onset of the treaded BeoVirus (I tend to upgrade/change my setup "infrequently"): BeoSystem 2500 (with blue speaker covers), BeoLink 5000, BeoSystem 7000 (complete; silver/black), BeoLink 7000, RedLine 60.2, BeoVox Penta, BeoVision MX4000 (black, motorized floor stand), BeoCord VX5000 (black), BeoSystem 4500 (complete), BeoCenter 9500, BeoLab 8000, BeoLab 6000, BeoVision Avant (original, 28" AR, VHS, green), BeoCenter 2300, BeoVision 3-32 (grey speaker frame, AR, motorised cabinet), DVD1 (grey), BeoCord V8000 (grey), Beo4, BeoSound Ouverture (w/ floor cabinet stand), BeoVision Avant RF (grey, 32", AR, VHS), BeoSound 9000, BeoCenter AV5 (blue), BeoVision 1 (yellow, motorized floor stand), Beo1, BeoSound Century (yellow), BeoCenter 1 (blue, AR, motorized floor stand), BeoSound 1 (silver, floor stand), BeoVision Avant RF DVD (grey, 32", AR), BeoVision 7-32 MkI (AR, motorized floor stand), BeoLab 3 (black), BeoSound 2, BeoVision 10-40 (grey speaker cover, AR, motorized stand).
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
Re: AR coating on BeoVision 10
When I first got my Beovision 3 the ARS wasn't as yet available for
it so I bought it without. Much later when B&O had brought the
screen out, I saw an ARS on eBay so I bought and fitted it. Must say, I
was a bit underwhelmed and couldn't really see much difference! But of
course others may disagree as I suppose it all depends on placement of
the TV as regards reflections.
I'm not sure also whether or not
the coating actually darkens the image somewhat, but this is purely a
subjective comment and others may have 'evidence' that it makes no
difference whatsoever.
It's a pity you can't view 2 BV10s, one with and one without and do an A/B comparison for yourself!
Finally,
I'm sure some members will be able to give a more objective answer
especially those with 'links' to dealerships where the benefits or
otherwise of ARSs must have been discussed.
Good luck from an envious person.
I
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
In my experience, the coating (on the Beovision 1 and 3) is very good, the problem is the screen behind the glass is still shiny!! That's why ultimately the difference is small... it depends on what the panel is like (if it is matte or shiny)
Brian Waddell
- Joined on 04-16-2007
- Edinburgh, Scotland
- Posts 69
Hi
From a scientific viewpoint, anti reflective coatings have been with us for some time. Looking at lens variety, ie instruments, cameras, spectacle lenses, the difference between coated and uncoated lenses are huge. The specification for the BV10 states 'anti reflection coating on both sides' is important as all the previously mentioned lens systems have multi layer anti refelection coatings of perhaps 6 to 8 layers each a few microns in depth and the BV10 has a single. The point about many coatings is that a single coating only works for a small part of the visible spectrum and a multi layer works over the whole spectrum.
Coatings prevent reflections, and an uncoated screen or lens will reflect 4% of the incident light from each surface. This can be very annoying as glare. If B&O were to visit lens manufacturers and find out how to coat multi layer treatments, then the arguments between yes and no would be more viable. Multi coating on lenses can reduce reflections from a suface from 4% right down to 0.1%. Now that would be spectacular on a tv, although I think the final price of the BV10 would more than double, were the technology to be available for this process to take place.
Brian
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
KMA:
In the UK the AR screen will be fitted as standard so there will not be an option to not have it.
Opman
KMA
- Posts 101
Thank you for your thoughts.
Elsewhere Peter recommended AR coating for the BV10, and the new B&O Magazine / Catalogue also explained the benefits with regard to perceived picture quality.
In my country, the AR coating is not standard in the "starting from" pricing. It costs 750 euros extra. However, my dealer made a very good offer, making the decision pretty easy for me.
Going to order one with the floor stand and AR coating tonight, provided that the dealer has reasonably reliable information on the actual delivery time of customer units. I've heard weeks 49 and 50 mentioned thus far.
That would be in time for Xmas
KMA
Dave
- Posts 2,328
KMA:
Ummmmm, of course it does!!!
Zoe
- Joined on 05-16-2007
- Posts 5
For your information - the coating on BeoVision 10 is a multilayer coating and the reflections are reduced from 4.3% to 0.5% - so the difference is quite significant.
Peter
- Joined on 02-12-2007
- Posts 9,572
Hadn't realised that the wall mounted BV10 at the show had no AR - pleased about this as it was poor for reflections. The floor stand one was much better and had the AR so from that, I would rate it as essential. I had put the reflection down to the atypical surroundings but everything becomes clear!
Page 1 of 1 (9 items)
