Latest post 11-02-2009 5:06 PM by Emil. 2 replies.
Page 1 of 1 (3 items)
  • 11-01-2009 4:18 AM
    • Emil
    • Top 500 Contributor
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    Assistance needed - can't controll BM5 with Beo4 in PC mode
    I'm having trouble with my BM5 since yesterday. My BM5 is connected to a BV 7-32 MkI and for some reason the BM5 no longer responds to the Beo4 when selecting PC on the Beo4. I can see the BM5 main menu on the tv (provided that the system is already up and running) but no response to Beo4 commands. When pressing menu I get the BV 7-32 PC source menu rather than the BM5 menu. I have also noticed a red "dot", pretty much like the "off" button in Beoplayer, in the lower right corner of the TV picture which I don't think have been there before.
    Nmusic still works fine in main room as well as in link rooms but I can't make use of the tv anymore. It's if I had just hooked an ordinary computer to the tv, i.e. I get a picture on the tv but nothing more.
    I have tried to reboot the system, made a recovery of the system, changed the ML cable to a new one which only runs between my tv and the BM5, but still no success. Any assistance how to solve this problem would therefore be highly appreciated. BM5 is normally set as no Audiomaster since I have a BS 3200 as Audiomaster. After changing the ML cable I have however tried to set is as AM in option 0, 1 and 2 as well.
    Best regards,
    Emil
    Inflagrante
    Filed under:
  • 11-01-2009 6:32 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Assistance needed - can't controll BM5 with Beo4 in PC mode
    Hi Emil,
    I replied to your post in the General Forum, but you are right, this may be a better place...
    If I understand correctly your BM5 got the standby button on screen, doesn`t respond to Beo4 commands in the mainroom but from linkrooms - is this right?
    The red dot in deed indicates a standby mode - usually after a reboot/recovery. Pressing PC - GO should activate your BM5.
    -first step: disconnect the BV7 from the mains for about 10 minutes (you have your PIN code....?!)
    -second step: press PC - GO - does the red dot disappear?
    - third step: try to activate BM5 from linkroom py pressing PC  - GO (will work only from BL3500, BV6, BC6...)
    - fourth step: check your option settings. I assume the speakers are connected to the BV7. So V.OPT should be 2, A.OPT 0 and BM5 NO audiomaster.
    Hope this helps.
    Stefan
  • 11-02-2009 5:06 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    Hi Stefan,
    Forgot to thank you in this forum as well (double posts in the BS5 forum and the General forum).
    Problem solved with a second recovery.
    Best regards,
    Emil
    Inflagrante
