1st March February 2012
Latest post 11-04-2009 4:43 AM by JC. 7 replies.
10-28-2009 3:54 PM
harrykym
- Joined on 08-04-2008
- Rossendale
- Posts 86
Someone must know? Beocom 2
Hi Beoworld!!!
My beocom 2 has stopped working, very odd!! It was working fine up to around week ago. Then kept flashing with the B&O logo couple of times a day but only when on the stand and now just stopped working, dead! Any ideas?
BS-3, BS-1, BS-OVERTURE, AVANT-28"RF, AVANT-28" DVD, AVANT 32" RF, 3xBEO-4, LC-1, 4xBEOCOM-6000, BEOCOM-2, A9 KEYRING, DVD1, Beosystem 10, BEOCOM 3, BEOLAB 2500, BEOSOUND CENTURY, BEOLIT 707
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
Re: Someone must know? Beocom 2
Sorry to suggest the obvious, have you tried switching off the handset and powering off the base? It sounds cliched but it sometimes works and enables the handset to re-connect with the base.
Opman
harrykym
- Rossendale
- Posts 86
Hi thanks for the advice just wanted to update you
I turned the base off and let the battery run down, left it for a couple of days then re-registered the phone. Now at this point it worked perfectly for the last 24hrs until the information started to flash!! And now says “no contact with base” if I take it off the base it just keeps turning itself off and then back on!!
Is this a battery fault? If so, I understand the battery can only be changed by an B&O engineer? Does anyone know what this will cost?
Many thanks guys.
JC
- Joined on 04-16-2007
- Yorkshire / UK
- Posts 621
Sounds definately like a battery issue. King Street Manchester did mine instore, ask for Graham.
Jonnie
harrykym
- Rossendale
- Posts 86
Thanks Jonnie,
how much did it cost?
James
JC
- Yorkshire / UK
- Posts 621
Hi James,
Think it was £25. Give them a quick call before you make the journey just to make sure they have a battery and they are stil providing the service. It was last year I had it done.
Jonnie
Page 1 of 1 (8 items)
