Hi all!
I checked my service manual but I can't find any reference voltages/test points for the adjusting of the idle current of beomaster 1200 power amp. (BM is running hot, so I'll replace trimpots and electrolytic caps and readjust)
I have a working one, so I can take reference voltages from that one if no one knows. But, I don't know where to measure!
Any comments are greatly appreciated!
Correction: trimmers to be adjusted/replaced are the 500 ohm ones, No 399 and 429 in the service manual, right?
I found reference voltages in the schematic too, but which one should I use as guide in adjusting the idle current?
