Latest post 10-27-2009 4:39 PM by Russ. 3 replies.
Page 1 of 1 (4 items)
  • 10-26-2009 8:59 AM
    masterlink/datalink
    ls
    i am the owner of a house with a masterlink system.  in one room though there is 8-pin socket.  is this a datalink outlet? is there a way to connect to a beovisio mx 4002 with masterlink connection?
    thank you!
  • 10-26-2009 9:20 AM In reply to
    Re: masterlink/datalink
    Masterlink is a long, flat, rectangle socket, while Datalink is DIN.
    I do not know how many pin has a Datalink socket.
    Powerlink (for the speakers) is also DIN, it has eight pins.
    You can find details about the different connections here:
    http://www.beoworld.org/beotech/index.htm
  • 10-26-2009 1:45 PM In reply to
    That sounds like a Powerlink socket. Datalink is a 7 pin cable. You can sometimes use a powerlink cable as a Datalink one though... Cut the central pin. It does depend on what sort of powerlink cable it is though - there are a variety and not all are fully wired.
  • 10-27-2009 4:39 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Are you sure that the house is wired for MasterLink, not Master Control Link?  A single 8-pin DIN socket just might be the original MCL for a BeoLab 3500/LCS-9000.
    If, we're sure that it's all ML, then that is definitely a PL socket, the question becomes 'Why?"
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
