Latest post 10-25-2009 6:36 PM by geearr. 4 replies.
Page 1 of 1 (5 items)
  • 10-24-2009 9:15 PM
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    MX7000 PUC list
    Hi
    I have an old MX7000 which is fitted with a STB-C.  What keys have to be pressed on a Beo4 or BL1000 in order to display the list of set top boxes that are covered by this particular version of the software?  At the moment, I have tried Menu 0 0 GO but all I get is the software version 1.1.
    All ideas appreciated.
    Geoff
  • 10-25-2009 5:18 AM In reply to
    • sverreh
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Norway
    • Posts 88
    Re: MX7000 PUC list
    On the Avant/MX 4200 I find the list of STBs in the Setup menu.  In Connections, when I define STB to be one of the connections, the list of supportet set top boxes appears and I can see the complete list.  I don't know the STB-C for the MX 7000, but I would expect it to be something similar.
    Sverre
  • 10-25-2009 6:39 AM In reply to
    • geearr
    • Posts 301
    • Gold Member
    Re: MX7000 PUC list
    Thanks Sverre
    The connections options in the setup menu of the MX7000 are very limited and there is in fact no mention of a set top box.  According to the STB-C instructions, everything seems to be done under the V AUX source and I don't see any PUC list there.
    I'm still in the dark at the moment but that list must be able to be displayed somehow.
    Regards
    Geoff
  • 10-25-2009 7:28 AM In reply to
    • tompa
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    Re: MX7000 PUC list
    It´s not possible with MX7000 to get the puc list out of the menu, you have to se on the chip in stb controller module or if the technican
    that insert it, have label it on the backside of tv , then you have the table version i can help you to see if the box you want to use is
    supported(or you check with you nerrest b&o dealer)
    Regards
    Tomas
  • 10-25-2009 6:36 PM In reply to
    • geearr
    • Posts 301
    • Gold Member
    Re: MX7000 PUC list
    Thanks Tomas
    Very helpful, at least I now know that I must stop fiddling around in the Menu system to try and find something!!  It sounds as if the next step is to take the back cover off from the TV, find the chip and get some information off of it.  I will try and do that sometime and then I might be able to find out what table is present and what STB's are covered.
    Thanks again
    Geoff
