Good evening. I have a somewhat odd question that I'm hopeful someone may be able to assist with. I recently bought a flat and the previous owner had all B&O equipment and had an excellent job done of wiring all the A/V cords into the walls. Redoing the A/V wiring job is quite difficult and costly, so I was hoping to re-use the speaker cables. Does anyone have experience (1) passing an amplified signal through the 8 pin DIN powerlink cable and (2) if 1 is possible, any guidance as to which pins would be best to use to transmit the signal.
My naive approach would be to pick two pins and transmit the plus / minus signals down the cable and see if it works.
I'm hopeful that someone may have some advice for me.
Thanks very much for you assistance!
