Latest post 06-17-2010 6:11 PM by Steffen. 6 replies.
Page 1 of 1 (7 items)
  • 10-23-2009 4:30 PM
    • Boss
    • Not Ranked
    • Joined on 10-20-2009
    • Posts 6
    Beogram 3000 Solenoid
    Hi Guys,
    I have a BeoGram 3000 (1985-1987) with a stuffed Solenoid. The little plastic piece in the middle of the solenoid is stuck and will not move.
    I'm just wondering if anyone can help me out or if anyone knows where i might be able to get my hands on one.
    I would really like to get this play up and running and your help would be much appreciated.
    cheers
    Jarrod
  • 10-27-2009 2:57 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Beogram 3000 Solenoid
    A well-known problem, and a relatively simple fix.
    Been there, done that!
    See these posts
    http://forum.beoworld.org/forums/p/28461/225759.aspx
    http://forum.beoworld.org/forums/p/24078/181038.aspx
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 11-09-2009 6:36 AM In reply to
    • Boss
    • Not Ranked
    • Posts 6
    Hi Guys,
    I'm still trying to track down a solenoid for my Beogram 3000 type 59xx. Can anyone help me or give me a heads up were i might be able to get one from. I'm having some trouble getting my hands on one!
    any help would be much appreciated.
    thanks
  • 11-12-2009 12:40 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Your chances of finding a new one are just about zero.
    You could probably find a used one in a parts unit, but that would fail in short order, so you wouldn't have gained anything.
    If you send me the main PCB, with the solenoid attached and stuck in, I can rebuild it for you.
    Menahem
  • 05-23-2010 12:52 AM In reply to
    • Boss
    • Not Ranked
    • Posts 6
    Hi Again,
    Sorry to bring up old posts but, i'm still in need for a solenoid for my BeoGram 3000 (1985-1987).
    I would really love to get this going again! Any help would me MUCH appreciated.
    thanks again
    Boss
  • 06-14-2010 5:15 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Pls check my website
    On the right-side, you will see some PDF links.
    Download the Beogram 4500 pdf, and inside, you will find complete instructions to repair the piston.
    If you do not wish to do the work yourself, I am happy to do it for you - Pls contact me on how to remove the main PCB for shipping.
    Menahem
  • 06-17-2010 6:11 PM In reply to
    Hi Boss
    You've been asking the same question 3 times now. Why not listen to Yachadm -he's trying to help you...Wink
