I'd say the cables would add less than five centimeters (two inches). However, you'd need at least 15-20cm behind that box if you intend to be able to check cables and/or swap them.
I don't have one, but cables are the same, no matter the box.
It might be possible to mount it vertically, thereby having the cables at the bottom, and therefore no ekstra space behind the thing.
