Latest post 06-13-2007 11:33 AM by Christian. 12 replies.
Page 1 of 1 (13 items)
  • 06-11-2007 1:25 PM
    beolab 8000
    Is that worth to buy bl 8000 now since it has released for more than 10 years or buy bl 3 instead.
    Filed under: ,
  • 06-11-2007 2:06 PM In reply to
    Re: beolab 8000
    Listen to both and decide which ones you could live with. It's the only way.
    Regards Graham
  • 06-11-2007 2:25 PM In reply to
    Re: beolab 8000
    Agree completely! There is considerable debate about which is better and the answer has to be whichever you like best!
  • 06-11-2007 2:57 PM In reply to
    Re: beolab 8000
    It's worth your pocket to get a pair of BL8000.
    IMHO, they will last more than 20 years, furthermore, these loudspeakers have a timeless design.
    Last but not least, follow your instinct. If you like them, go for it !
    Guy
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 06-11-2007 3:45 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Re: beolab 8000
    If you like the BL8000, go ahead and get them. You won't get an old shoe, that is shure! (I bought a pair 4 months ago)
    If you are not sure wether to buy BL3 or BL8000, then you need to compare their sound , as said before. There really is a big difference between the two, especially at high volumes. Judge yourself!
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 06-11-2007 3:47 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: beolab 8000
    They are both on a pretty even par..
    Both have their strong points and weak points.  As said before - have a listen and decide for yourself.  Everyone hears differently they say - so it's a personal choice as opposed to what a spec sheet tells you. Big Smile
    Lee
  • 06-11-2007 4:08 PM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: beolab 8000
    I spent a little time (only about half an hour) comparing them at my dealers several weeks ago. Both were against a wall (the BL3's were on floor stands), both were only ~6 feet apart and I listened to unfamiliar material at a distance of 8-10feet. My preference was for the BL8000's both audibly and visually. They just seemed to have more detail than the BL3's.
    After the visit as I mulled it over I became concerned that I had heard the BL3's whilst standing and I think the lens is aimed more for a sitting position - clearly the 8000's will be less affected by ear height. I did intend going back with my own material and re-listening maybe with the speakers seperated more and definitely from a sitting position but got caught up in a technical issue regarding driving both via line level sockets and haven't yet made the return visit. An option was also to audition at home, in situ as it were, clearly giving an even better opinion.
    SWMBO thinks the 8000's "look nice" and the BL3's "don't look like two grands worth"Laughing
  • 06-12-2007 12:17 PM In reply to
    Re: beolab 8000
    Definetely listen to them.  I prefer Jazz and classical but I also have a large rock & roll collection.   The BL 8K perform well.  Be ware, at very high volume, they struggle and sound strained.  BL 2 paired with the BL 8K helps the speaker at very high volume.
    I am not into subs.  Even the BL 2 can be 'slowed' and not as precise in rebroducing the lower octaves.
    Also, the bl 3 have a plastic ALT which I think takes away from their 'shine,' considering the price point.
    Listen, decide, buy, and enjoy....
    rd
    When I hear music, I fear no danger. I see no foe... Thoreau
  • 06-13-2007 4:37 AM In reply to
    Re: beolab 8000
    I disagree with Puncher. I have always found that my BL3s sound much more precise than the BL8000s and the placement of the sound is much more accurate than the BL8000s as well. Further more at a distance of about 8-10feet in my audio room my BL3s on the floor stands sound even better if you're standing. From what I can hear, I think the sound of the ALT is aimed to be projected from the angle of 90 degrees and upwards.
    I personally prefer the design of the BL3s especially with the ALT - bowler hat on top! And probably unlike everyone else on BeoWorld, I think the BL8000s do look dated now. When these speakers were released it was an absolute first to have a column shaped just like the BL6000s, BL8000s and BL1s. Nowadays Hitachi, Thompson, Panasonic and many other brands have all tried to imitate the column designed loudspeakers in their own way. The BL3s are completely unique in my opinion, and for the type of music that I listen to, playing in my room and at the average volume level that I listen to, the BL3s are better than the BL8000s.
    BUT, I do believe it is very fair to say that the BL3s don't outweigh the BL8000s entirely, therefore you should definitely listen to both speakers, in your own home too if your dealer is kind enough to organise this for you and make your own decission from there. All I have said is my opinion and how I see and hear things.
    Let us know when you've gone for the kill and which one you've chosen!
  • 06-13-2007 6:11 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: beolab 8000
    timothyhou:
    Is that worth to buy bl 8000 now since it has released for more than 10 years.
    Don´t forget it has been upgraded several times.
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Re: beolab 8000
    Sorry, double post.
  • 06-13-2007 6:28 AM In reply to
    • Puncher
    • Posts 9,588
    Re: beolab 8000
    Henry:
    In truth I had expected the BL3's to be brighter than the 8000's (maybe even a little harsh initially) because of what I had read before my visit. It turned out not to be so, hence my questioning the standing/floor mounting of the BL3's.
    I have re-read my original post and notice I failed to point out that the 8000's were driven from BS9000 a  while the BL3's were driven from a BS4.
    Rather an obvious difference to overlookEmbarrassed
    I reiterate - audition in the same setting, with the same source, with familiar material and decide for yourselfBig Smile
  • 06-13-2007 11:33 AM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    Re: beolab 8000
    Puncher:
    Should that make a big difference? I thought that the BS9000 was only superiour when used with digital out. ConfusedSmile
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
