SWISS_2:Very good. Please post your experience and final preference when you can for the other members.
I have my diNovo Mini since 2 days.
It is very easy to plug, no configuration needed (just press "Connect" buttons on the mini-bluetooth usb receiver and on the keyboard to establish the connection). My Beomedia 1 is locked up inside a furniture and the bluetooth communication is OK through the wood panels. Do not expect mouse reactivity like a standard wired mouse, the trackpad must be used slowly to reach the desired area on the screen at the first try.
The keyboard is actually very small, and only the thumbs must be used for best efficiency. All the essential system keys and caracters are present (French version for me so I have accents like "é", "à" etc). The trackpad is not very accurate because the thumb is quite big on it: I have to gently scuff its surface.
To sum up this keyboard/mouse is well enginered and very easy to use, I am happy with it ![Smile](http://forum.beoworld.org/emoticons/01.gif)
Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
