Latest post 10-18-2009 2:43 PM by Michael. 1 replies.
Page 1 of 1 (2 items)
  • 10-18-2009 12:06 AM
    • Karla
    • Top 500 Contributor
    • Joined on 08-19-2008
    • USA
    • Posts 81
    AVANT Control of DVR
    I just received the most current software upgrade to the AVANT, and now I am having intermittent trouble with controling the DVR. It is a Motorola DCH 3416, of which there is not an exact match. Could anyone give me an idea of which selection in External Controls that would be approximate this DVR in the software for 4.7L? Thank you in advance.
  • 10-18-2009 2:43 PM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    Re: AVANT Control of DVR
    Are you saying you lost functionality that you already had before the upgrade?  Or are you using a PUC  (device model selected in the Avant menu) that was added with the software upgrade to control your Motorola but it doesn't work very well?  Don't know that model but there aren't too many options for the Avant:
    1. Try some other PUCs to see if they work better.
    2. Talk your dealer into restoring it to the working condition (Assuming you had had control previously.)
    3. Try the Beo5 remote so you can program/have programmed to work however you want with the DVR.
    -Michael
