Latest post 06-11-2007 4:31 PM by Xseries. 8 replies.
Page 1 of 1 (9 items)
  • 06-11-2007 1:06 AM
    Refoaming Pentas
    I've heard of re-foaming the Cx100's when the foam breaks down. Also, I 've heard that the foam of the midranges in the Pentas goes bad.
    Couldn't we re-foam the midranges in the pentas??
    THanks
    Filed under: ,
  • 06-11-2007 1:40 AM In reply to
    Re: Refoaming Pentas
    Yes. The drive units are however not that expensive. However if you have the skills, it is obviously possible.
  • 06-11-2007 1:47 AM In reply to
    I have never seen foam rings of the correct size advertised but they may be available somewhere.
    New drivers are around £25 each in the UK.
    Regards Graham
  • 06-11-2007 2:39 AM In reply to
    Thanks guys,
    That's interesting, so the drivers for the CX100's obviously must be more, as everyone opts for re-foaming these....
    Thanks again.
  • 06-11-2007 3:01 AM In reply to
    About the same! CXs are a much cheaper initial buy though. C75 drivers on the other hand are much more expensive!
  • 06-11-2007 3:40 AM In reply to
    Hi!
    In Finland they charge 170€ for two new woofers for cx50!!!
    Even with new drivers the CX's are still not worth a lot but a good pair of Pentas could be worth approaching £1000 so it's economically viable to spend the money.
    Regards Graham
  • 06-11-2007 5:04 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    joeyboygolf:
    There's an ebay seller who sells the correct size foam surrounds - they are spot on too, I have someSmile
    Chris.
  • 06-11-2007 4:31 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Peter,
    Why are the C75 drivers more?
    Age or technical reasons?
