Latest post 03-04-2010 2:48 AM by Burnix. 13 replies.
Page 1 of 1 (14 items)
  • 10-14-2009 11:46 AM
    Zone buttom
    Hello and first of all, scuse for my bad english...
    I have only one 'zone' buttom in my Beo5 and i would like to add another 'zone', but it seems to be difficult...... It seems not to be possible to add a buttom in this menu.
    Can someone explain me if it is possible and how can i do?
    Thank you.
  • 10-14-2009 1:38 PM In reply to
    Re: Zone buttom
    Normally you define the zones you want at the start of the configuration process.
    In the configuration Tool click the TAB which says CREATE ZONE as below
    Type in the box what you wish to call the additional zone and then press "Add Zone"
    You can now add products to each of the zones you have created by going to the next tab along called "Choose Product"
    Regards Keith....
  • 10-14-2009 1:39 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Zone buttom
    Hello
    As you can see in de Config Tool, there are some tabs in the main window. The second tab is called Create Zones. Go there, type a name for your zone and click Add. A new zone will be created.
    My english is too so bad, but I hope you can understand my answer.
    Cheers
    Quim
    • Quim43
    • Posts 1,030
    • Gold Member
    Re: Zone buttom
    Ops, too late, Keith did beat me Stick out tongue
    Quim
  • 10-18-2009 10:06 AM In reply to
    Re: Zone buttom
    Yes, i have found it, thank you.
    But now i have another problem..... ok, i am newbie ....
    How can i turn back in the 'zone menu'?
    When i charge Beo5 and i turn it on for the first time, now i have 2 zones: Living room and Bedroom.
    I can select one zone, and everithing goes ok, but it seems not possible tu turn back and choosing 'bedroom'..... how can i do this?
    Thank you
  • 10-18-2009 11:50 AM In reply to
    Re: Zone buttom
    Going back to select another zone is quite simple as shown below
    You can press the right hand SCENE button at any time and in any screen and you will get something like the following screen which will always have a ZONE soft button as below, pressing it will take you back to the first screen.
    Regards Keith....
  • 10-18-2009 3:48 PM In reply to
    • Soren
    • Not Ranked
    • Joined on 05-04-2007
    • Kolding Denmark
    • Posts 56
    Re: Zone buttom
    Hi
    After I changed my configuration I hava "lost" my Zone Button under scene, the problem is both on my Beo 5 and on my computer when using the config. tool. that means that when I select ie livingroom i can not go back and select bedroom without connecting my Beo5 to the computer. is it possible to make new zone buttons?
    Søren
  • 10-18-2009 4:04 PM In reply to
    Re: Zone buttom
    Søren,
    Assuming your "Zone" button is not hidden and you did not delete it, then I am not sure how you managed that, unless you have found a software bug in the configuration tool.
    Whatever the cause of the problem, there is only two ways of correcting the situation:-
    1. Do the whole configuration from scratch again
    2. Manually edit your "Configuration.xml" file with a text or XML editor
    The "Zone" commands use the "Navigate to absolute menu" in the navigation tab, however the configuration tool has this grayed out and so you cannot add it with the tool.
    Regards Keith....
  • 10-26-2009 2:56 AM In reply to
    Re: Zone buttom
    ......i lost my zone buttom too.....
    It is non hidden. Maybe i accidentally deleted it and now i am not able to readd it......
    Can you please explain 'step-by-step' how to solve this problem?
    I told 'step-by-step' because i don't speak english very well and i am newbie, so, it is a little difficult for me to understand many technical-words.....
  • 12-06-2009 3:05 AM In reply to
    Re: Zone buttom
    ...up please....
    Can someone help me?
  • 02-16-2010 9:14 AM In reply to
    Re: Zone buttom
    ....Can someone please help me explaining the procedure 'step by step'?.....
  • 02-26-2010 2:02 AM In reply to
    Re: Zone buttom
    Some help?...
  • 03-02-2010 11:39 AM In reply to
    Re: Zone buttom
    Can someone help me please?
  • 03-04-2010 2:48 AM In reply to
    • Burnix
    • Not Ranked
    • Joined on 09-10-2008
    • Denmark
    • Posts 62
    Re: Zone buttom
    My recommendation would be to start all over from scratch. Delete the current configuration (or rename it) and make a new configuration. By renaming the old one you always have the possibility to compare the new and the old one.
