I have had a xtra speakers kit to my 4500-system for a couple of month without any problem - until a few days ago.
Sometimes the tranciever is dark and doesnt respond to button press or remote. When I disconnect/reconnect the power cords to the Beomaster 4500 all works fine again.
Anyone with an idea?
I have a junction box for lengthen the MCL-cable at the attic, is that a problem no when the temperature drops below 0 (Celsius)? Is there someting else that can disturb the communication between relay box and the 4500? Is there any communication when the systems are i stand by? It is in stand by mode the problem has come so far. Maybe it is some component that ususally fails inte the relay box which is easy to replace?
What do I now...? ;-)
/T
