Latest post 10-15-2009 4:07 PM by ericcardi. 4 replies.
Page 1 of 1 (5 items)
  • 10-12-2009 6:03 PM
    beocom 2 - display doesn't work anymore
    My Beocom 2 works normally, but on the display after having the image frozen at 3:48 for a couple of days, everything disappeared. Any Idea?
    Thanks, Emanuele
    Filed under:
  • 10-15-2009 1:31 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: beocom 2 - display doesn't work anymore
    Simple question, but it often solves this issue...have you powered the phone down and re-started it?
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 10-15-2009 2:58 PM In reply to
    stupid question: how do you do that?
    can't find anything in the manual....
  • 10-15-2009 3:20 PM In reply to
    Press and hold the bottom button till the hand set switches off. Press it again and will restart.
  • 10-15-2009 4:07 PM In reply to
    Yes! Working again. Thank you so much!!
