1st March February 2012
Latest post 10-16-2009 4:50 AM by madslp. 18 replies.
10-12-2009 3:39 PM
madslp
- Joined on 09-06-2009
- Posts 58
Beo4+ - A new generation......
More 2 come...
BS 3500, BL 8000, BL 6000, BL 4000ice, BL2000, BL3, BL2, CX100, CX50, Cona, MCL/ML, BPC2, MX7000, MX4000, Beotime, Beo5, Beo4, Beo4cinema, Beo1, Beo1000, A8.
madslp
- Posts 58
Re: Beo4+ - A new generation......
madslp
- Posts 58
I'm just finish, the details are still secrets..... But this is the best idea ever...
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
Very intriguing...
Does it have a second IR transmitter installed (non beo code)?
madslp
- Posts 58
I have installed another feauture, because I have Lintronic controlling my ir codes for other non beo...
THIS IS THE ...
This will still remain a secret...
madslp
- Posts 58
3 Days 2 come....
Electrified
- Joined on 10-05-2009
- Greater Copenhagen, Denmark
- Posts 404
It really IS an MBP/iPod remote added, isn't it? Very small - especially without the battery and casing, and if I recall, it has the same number of buttons as that thingy (five).
Do you turn it 180 degress to use the added buttons, or have you routed it to the top?
madslp
- Posts 58
Hey... The truth is I have added gyration to the remote... Then I can use it as mouse in Windows...
Electrified
- Posts 404
madslp:
Haha, that figures. IMO, you should have chosen Wii's gyration instead. That way you'd be able to swing it as a bat.
Seriously, is it an iPod/MBP remote? I really think you should come clean now!
madslp
- Posts 58
The Beo4 containes gyration, i have added a module! Then you can use it as a mouse in windows!!
This idea is much better than wee, with wee, you have to point to the screen. And the swíng function, I dont care.
I also have a lot of other shortcuts, with the 4. button..
I work with FM, so the range is about 30 meter.
I changed the remote, with only 2 batteries, it worked on 3v.. The gyration module runs 1,5V
The keypad is from Beo4, removed the colors. But a keypad from Beo1 would be better..
Then I can use it with window media center, and with Lintronic, i can remote non beo..
Electrified
- Posts 404
Mads,
I assume you're danish? If so, transmitting on the FM band is illegal. Also, I hope you live in a house so your neighbours don't get bad FM reception whenever you fiddle your remote.
With that said, I have to say I find your entire project rather innovative and big kudos to you for taking it on :)
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Looks like fun!
It's butchery though if you ask me... :-S
Daniel
- Svinarp, Sweden
- Posts 1,284
Electrified:
It used to be, but now you can use a FM sender to listen to your iPod on the car stereo. So I think they have changed that law a little bit. At least in Sweden, but I guess it's the same in Denmark.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Daniel:
I believe it is EU-wide. However, the maximum allowed transmitting power is very small, so the useable range is not much more than some meters... and most of them sound like crap anyway
madslp
- Posts 58
I'm working on a video so peple can see how smart it is...
The other remote i bought here in denmark, so about the FM transmittin, i think it's okay... And I dont care about my neightbours...y
But GYRO is the future...
madslp
- Posts 58
butchery??? It's innovative..
Page 1 of 1 (19 items)
