Latest post 10-12-2009 12:19 PM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 10-12-2009 7:51 AM
    Beogram 5005 speed up
    My Beogram 5005 has a tendency to speed up all of a sudden, sometimes.
    Not exactly sure when, as its not always the same but i am pretty sure its when i am playing 45s.
    It starts ok then suddenly its speeds up and stays that way. I think the sped up speed is the correct speed.
    Any ideas?
    thanks
    Tom
  • 10-12-2009 12:19 PM In reply to
    Re: Beogram 5005 speed up
    Main drive band would be the first thing I would change. Chances are it has never been changed and you will be amazed at the difference.
    Still available from B&O dealers and worth doing anyway.
    Regards Graham
