The most obvious thing is a change in configuration? Either you or the dealer has changed the sharpness or something else on your TV and the software upgrade has reset this back to the default setting?
As you've gone from a very early 7-40 sw through to something more recent, this may account for the change in configuration? I know the sharpness setting was made in to a user-definable option, for example.
