Yes, the TX uses a metal ruler. But everything is fine there...the sensor and the LED work fine. And as the BG stops and plays the record the problem can't be there, can it?
As all connections are ok the problem has to be somewhere on the main PCB; most likely around TR35.
So I checked all parts mentioned in the service flowchart (D45-46-47-48-49-50; TR35-40, C40-41). All were still good, but I replaced the two caps and the two transistors anyway (why not - I still had new parts).
And now the problem got even stranger. At the first try it didn't work - just like before. But since the second one speed is stuck at 45rpm! Which means when I start the BG it will start up in 45rpm mode and will play LPs in the same. I can still change the speed manually - so it's more or less the same problem, only the speeds changed!
Does this mean IC3 is faulty? I don't have an oscilloscope to check...
Edit: Ok, forget that part. 33rpm doesn't work at all now. Turntable stays in 45rpm mode no matter what you do....
