Calling all Techies.
I'm new to B&O systems and now I own one, I have encountered a problem.
I bought this off Ebay as working, but when it arrived although it is in superb cosmetic condtion, the CD doesn't work. I have tried to get the seller to take it back, but he is sure it worked when it left him and isn't prepared to give a refund. He might be right and does have good feedback, but that doesn't help me!
I do know quite a bit about electronics and have carried out a few checks on the unit. All voltages appear to be correct (I did expect to find some physical problem such as a plug out but nothing so simple). The door opens as it should but when you insert the CD, other than a brief chattering from the laser (which I would expect), then CD doesn't spin at all. When you select  CD and play, all you get on the display is "CD  <>" If you press play, again you get the slight chatter from the CD laser. I would have expected that the disk would have spun, even if the laser was defective. However, as I have never had it working, maybe this isn't the way it would normally work.
The CD unit is PSS/M2/VO 9539.
Can anyone give me any advice on the possible fault?
I'm trying to locate a service manual if anyone can help. I understand that there are service modes which might help me determine the fault.
If I have to replace the laser and control board, can anyone direct me to a supplier?
Thanks in advance.
Steve (Silkyss)
