Carolpa: your to negative!
Yes I know I am, but I am also a little hopeful.
Carolpa: go download the latest version.
The "latest" MAC version is still the old BMLINK that I use every day.
This is the "latest" WINDOWS version on B&O's main site, and which I can't use on my Apple ... I think/hope there is a newer version coming for Windows users (and maybe Mac users):
Version 5.02.01
This new version of BeoPlayer is designed for use with the BeoSound 5 / BeoMaster 5 or for BeoMedia 1 use.
New features included:
- It is now possible to hold the BeoPlayer control and dismiss hiding
- If you are using BeoMedia 1: You are not required to download this new release, but are encouraged to:
- if you experience problems using your current version, or
- if you have updated to a Windows version not supported by the current version
- The Guide for the new release does not describe use with BeoMedia 1 and therefore a separate Guide (available in English only) must be used.
» English Guide
Error correction:
- A number of minor error corrections have been made.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
