Hi all,
I have a beosound 9000 that I am mainly using as a Home cinema sound system.
Shall you please suggest me a remote control that I can use to control just the volume?
I don t want to spend€200 for the original one.
The beolink 1000 will work for this purpose?
Thanks to help me.
Ciao
Andrea
Hello Andrea, and welcome to Beoworld. Yes a Beolink 1000 will work perfectly as it uses the same I.R. codes as the Beo4.
Craig
Why not a B&O phone with volume controls?
My 9000 is just one part of my AV setup. I use a Harmony 880 with good results.
BeoSound 9000, Beolab 8000, BeoLab 4000. Beogram 4002/Grado Gold Amina conversion.
Daniel: Why not a B&O phone with volume controls?
True enough but if he doesn't wat to spend $200 on a remote then I suspect a $500 telephone will be even less desirable. A beolink 1000 will be just fine.
Chris.
