Latest post 10-13-2009 4:47 AM by sking. 2 replies.
Page 1 of 1 (3 items)
  • 10-07-2009 1:16 PM
    • sking
    • Not Ranked
    • Joined on 08-12-2009
    • Posts 4
    Beovision 1 tuning with beo 4 remote
    I have a beovision 1 that needs re-tuning due to a house move.
    A few issues:
    -pressing 'menu' on the beo 4 remote does not bring up a menu on the tv screen(all other controls, channel change, teletext, stand, work just fine)
    -after going to the 'add' (hold red dot+list) and selecting 'v.setup' i now have the 'v.setup' option under normal 'tv' setting but this also does not bring up a menu on the tv screen...
    any help would be great!
    Filed under:
  • 10-11-2009 6:21 PM In reply to
    Re: Beovision 1 tuning with beo 4 remote
    When you press MENU on Beo4 you get the options box at the centre bottom of screen. >> until box reads SETUP
    From memory i'm afraid!!
    Regards Graham
  • 10-13-2009 4:47 AM In reply to
    • sking
    • Not Ranked
    • Posts 4
    thank you so much! i was nearly pulling my hair out...
    unlike when pressing the 'list' function where you get helpful arrows >>, there is no indication at all when pressing menu that more options are available left and right. Tricky stuff for the newbie!
